Remote clutch bleed
Remote clutch bleed
Has anyone here installed a remote clutch bleeder? Seems like a simple but brilliant solution for clutch bleeding, especially if you track your car and bleed it a lot. Where did you install the bulkhead fitting for easy access?
https://www.demonspeedmotorsports.co...?categoryId=-1
Given the clutch fluid is physically partitioned and separated from the fluid that goes to the brakes, all the way to the brake fluid reservoir, is it really necessary to bleed it frequently?
I thought they shared the same reservoir?
Agree with you. Also my 997.2's clutch has a recirculating valve. In essence fluid is not self contained and is part of the brake system.
I do mine at the beginning of each track season. I had it cause issues my first season with it, so just cheap insurance. If the adapter was $30, I'd buy it. At $70, I'm willing to struggle a bit once a year to get it done.
Good to know. Thanks!
