C4S Radiators
C4S rads are the same as the turbo, fairly pricey. I found the best price so far is from Rockauto. I have been looking also at CFS rads, it seems that both left and right are interchangeable, and are cheaper.
let me know if you find something cheaper,
cheers!
Pelican Parts has the Behr radiators for about $450 each, & they’re specifically for the C4S.
A nice booty doesn’t come without a cost. 😂
Those were the cheapest I could find and I bought & installed them in my 2003 C4S a couple of weeks ago. They were a perfect fit and good quality. I hate to say it but you just missed a January deal with 15% off (which I was lucky enough to get).
This was the first time I had done it so I had some learning as I go that might help. If you are DIY, other than the pelican steps, here are some tips:
- If you think there is any rust in there at all, spend a bit more and replace the fans too ($100 each from rockauto). You have to take them out anyway so it's not any extra time. Mine looked pretty bad but I didn't have replacements when I did the exchange so had to put them back in.
- there are 3 hoses, 2 large & 1 small right at each radiator (supply, return, & breather). If I had it to do again I would probably replace those hoses & the clamps on them as well just for peace of mind (and I could've removed the previous ones without worrying about damaging them).
- It's easier to disconnect the hoses on the side connected to the wheel well and then take them off the radiator after it is out. To disconnect/reconnect the hoses at the wheel, the solid tubes the hoses can be pulled out of the clips at the wheel base to give you more room to work with.
- There are small washers to help connect to the bracket (#16 in this diagram: http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=996-99-05§ion=105-15). A couple of mine had nearly disintegrated and I spent like 2 hour driving around trying to find a near match. They are cheap and it won't hurt to have them handy. You need 6 for each side.
- The #17 clips in the diagram above are easy to remove so don't force them. You just have to lift the tab above the post and slide the clip out. You need to remove the one closest to the center of the car before you can remove the bracket with the radiator.
If you have any questions, I'll try to answer.
EDIT: Also, I was shocked at how bad the radiators looked at the lower back corners behind the AC condensers where crap just gets stuck and works into the radiator. I mean, they were so corroded and leaky I'm amazed I didn't have problems sooner. The connections between all the hoses were perfect. Unless someone has been disconnecting & reconnecting them a lot, I imagine it's more likely the radiators are leaking.
The cooling on these cars is only a problem when you are stuck in traffic or on the track. Being stuck in traffic is a result of the fans and the airflow. Making sure enough air is moving past the front rads is how you keep the car co. Remember, your engine is only generating 10HP worth of heat. Larger radiators will not help.
On the track, a 3rd radiator will probably provide the same cooling as the larger radiators for less cost.
If the idea of ordering from overseas bothers you, I found a pair from FCP Euro for $770 shipped. They claim a lifetime warranty on all their parts.
Next for me is to flush my whole cooling system so that new antifreeze & old antifreeze don’t mix.
Any thoughts on replacing the hoses that hook to the radiators vs just replacing the o-rings? The hoses aren’t terribly expensive, but they do add up. The hoses, themselves, seem just fine.
Thanks, everyone, for your advice on this!
If there was another reason for doing the work, like intermix, I'd be tempted to replace the hoses as preventative maintenance, but that isn't your situation.
One other tip - a vacuum coolant filling tool is almost a necessity on these cars to get a full fill without air being trapped. The UView Airlift or similar (I have a similar tool that works well enough, but if I did it over again, I'd have bought the UView).
Bought the Schwaben coolant flush kit and had to remove the lid strut to fit it onto the reservoir.
Removing the frame that holds the rad and fan together was easy leaving the ac condenser hanging.
Check out Ashai's thread for a great step by step.
