Coolant hose connections
I thought someone might save me some time looking back through diagrams and help me identify routing for a couple hose connections. I dropped my engine and somewhere in the process lost a couple of my hose labels. Which hose of picture 2 (coming from the t connector going to t stat) and 3 (hose going to hard return line) connect to the t connector in picture 1 going to the coolant reservoir? And then where does the other hose connect to? It will probably make sense when I get the engine back in but I believe picture 2 connects to the water reservoir t (picture 1)? But I'm trying to remember/see where the other would connect. I'm not seeing another hose connection on the engine. I tried to keep that all straight with pictures and labels but it's been a few weeks since I took the engine out.
Picture 1
Picture 2
Picture 3
Picture 1
Picture 2
Picture 3
Received 1,184 Likes
I don't know if a diagram will help, but here is one. The small nipple on #18 is the coolant line that goes to the AOS.
http://www.autoatlanta.com/porsche-p...section=105-05
This. I changed my coolant expansion tank not too long ago. It will be obvious once the tank is in there that the hose in pic three can only reach the barb next to the coolant tank vent valve.
