996 Forum 1999-2005
996 running 18" SportDesign and Pirelli PZero Rosso's - What pressures?
Old 01-27-2004, 08:55 AM
Beno
3rd Gear
Beno's Avatar
Question 996 running 18" SportDesign and Pirelli PZero Rosso's - What pressures?
Hi All
I've read a lot about the need to keep a watch on the tyre pressures as the car can handle very differently due to minimal differences in tyre pressure.
What pressure F/R should I be running? I have searched the forum with little joy.
I do not have a GT3 but I do have the GT3 Aerokit and therefore the wheels - thought you may be the best people to ask.
Cheers
Beno
Old 01-27-2004, 06:45 PM
Davidmichael
Davidmichael's Avatar
Porsche recomends 36 lbs front, 44 lbs rear for 18" wheels. That's what I run on my 996 C4S.
Old 01-27-2004, 06:50 PM
Eric - Plug Guy
Basic Sponsor
Eric - Plug Guy's Avatar
Watch your tire wear. After a thousand miles, see what's going on with the factory pressures. If you notice problems, you can drop a couple pounds too, and then see how they wear.
Also, if you have really bad roads or find the ride too harsh, you can probably drop pressures by 5% all the way around.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old 01-27-2004, 11:25 PM
Davidmichael
Thanks, will do
Old 01-28-2004, 02:06 AM
BayArea Jimmy
BayArea Jimmy's Avatar
After some experimenting, I settled down on 35/39 on my C4S. Pilot Sport N1, Stock alignment/tires.
Old 01-28-2004, 05:47 AM
Waz996
Waz996's Avatar
36front/44rear.. gone +250km/hr for over 20minutes and reached 280+km/hr for a few minutes.. no problem!
Waz
Old 01-28-2004, 10:46 AM
RJFabCab
RJFabCab's Avatar
Default Factory recommendations are 36/44...
For 18" Rossos I have found that 32/39 f/r cold pressures end up at 36/44 after hot laps.
Old 01-28-2004, 01:28 PM
TT Gasman
TT Gasman's Avatar
Ambient pressures at 36/44 works pretty well on the street, or you can try the stock Gt3 specs (34/39). On the track I aim for 36/44 hot as well.
Quick Reply: 996 running 18" SportDesign and Pirelli PZero Rosso's - What pressures?
