Danmar M6: Perfect 996 Home Lift
#32
Congratulations. Nicely done. Once you go with an actual lift you won't know why you waited so long. We are fortunate to have a lot of variety to choose from.
Mine is in a nine foot ceiling with a 22 by 23 foot floor.
There are lots of 4100 lumen 5000K 2 bulb by four feet fixtures on the web (about $25 each) to bring daylight into your work space.
#33
Bolts into anchors embedded in the concrete are the only thing holding it up.
#34
Very cool! I hope to get one sooner or later. Also, thanks for posting the width that you set the posts apart.
#35
Max capacity of this lift is only 6000 lbs. The PD58 wej-it anchors are listed as having a 16,500lb ultimate tensile strength in 4000 psi concrete. Working loads should be kept to under 4125lbs per anchor. Not sure what this translates to exactly in 3000 psi concrete, but you have 5 anchors per post. If each post will see a maximum of ~3000lbs, the lift is operating within a large margin of safety. With the liability involved, I'm sure the product has a comfortable factor of safety.
#36
With the full "to ceiling" height I opted to tie it into the joists as well because ... What is too safe? See attached pictures. It is very stable.
BendPak (no affiliation) makes this specific model in different heights. But this option is permanent on the floor. The ones that can unbolt and move have advantages of their own.
The top cross bar holds the ram and cables so there is nothing on the floor. The extra (small) padded bar just below the top trips a limit switch to prevent topping out the car during an inattentive raise.
No matter what other lifting method I used prior to this the side to side angling of the car was unnerving, both going up and coming down. There is no way to make jack stands stable with a side load. And the higher you go the more side leverage you get. A proper lift is peace of mind wrapped together with proper access to the bottom of the car.
We are fortunate to have so many options amongst a number of manufacturers.
#37
Six 3/4 by 6 inch cement anchors 5 inches deep across 12 by 17 base plates. Rated for 7000 pounds.
Francis
#38
Last year we completed construction of our new home.
Wife wanted an open floor design, I wanted a three car garage with 14 foot cielings.
We ended up increasing the size of the house so that the garage wouldnt look out of place and unbalanced next to the house lol
Ordered a Rotary lift as thats what all he shops around me use but there ended up being a beam running above where my right post would be bolted down. Ended up cancelling the Rotary order and bought a Atlas 2 post lift.
Ended up saving some money and so far I have no complaints.
#39
#40
The 996 needs "DGI X" plates too.
#41
#42
#44
Grand Prix. A relatively new offering. Been out for about a year. Introduction was delayed as the safety standards were revised and BendPak had to go through third party testing on all of their existing lifts before new products could be brought on line.
