LN Engineering Sump Guard Plate Review
#62
Thought i would give a minor update. I took the skid plate off while doing other repairs. I happen to have really thick insulating foam tape. I decided to add it to the entire side that faces the sump. While it helped some, i would say the noise is still 70% present.
#63
Has anybody tried a stethoscope on a engine that had the noise and took the plate off?
Can you hear the noise internal to the engine?
Got to wondering what the source of the harmonic might be..
FWIW,, most skid plates use grommets and washers to isolate the bash plate from the bolts.
#64
I installed my LN skid plate today and have to agree with those complaining of increased noise. Anything above idle yields a tremendous amount of noise into the cabin that was not previously noticeable.
#65
In truth i almost hate driving my car since installing mine. I would take it off if it didn't sit so low. I was hoping by this point LN would have reached out with a fix for this
#66
Google search bolt with rubber washer as an example.
Another idea is a damping sheet, as heavy as possible, we use them all over the car to damp noises and vibrations.
#68
Do you have a 2 quart deep sump? If not you will not need this particular skid plate. This plate is only needed because the 2 qt deep sump sits very very low. If you are stock then there are several options available to you
#69
I used rubber washers and have no noise or vibration issues.
Ratchet1025 (02-12-2020)
#70
Agree. Charles is typically all about making things right. Apparently not when it comes to a $300 piece of sheet metal. I have no problem paying for something that meets a need. For example, no problem paying the $700 for the 2qt sump. It's well made and meets a need. I would have no problem paying $300 for a skid plate either, but the fact it transforms the car in a negative way, and the only response we get from Charles is that they have never seen it happen does not feel like an acceptable answer, or the fact that many of them come and they don't fit so you have to bend it to make it fit, only to find out that it makes a ton of noise. I have not tried, but I am sure at that point it could not be returned.
#71
Now the deep sump worked perfect. prior to i had low oil pressure on heavy G turns. That problem is resolved. Major thumbs up on that product!
#72
Have you seen their new billet sump plate?
#74
#75
