OEM 997.1 Turbo wheels FIT 2003 C4S?
Brothers, I need to confirm if a set of OEM OEM 997.1 Turbo Wheels will fit without Spacers or Drama my 03 C4S? the details are below:
(19"x8.5" front (P/N: 99736215605), 19"x11" rear (P/N: 99736215202) Tires are 235/35/19 front and 295/30/19 rear
Currently I have the Stock setup 8.5 Front 18x11 Rear with the same tire size as above. Thank you all in advance.
I would say yes, as the OEM turbo are for the widebody and the offsets should work
I have exactly the same diameter and wide, with the same tire size on my C4S. But it also depends on the offset of the wheels.
