Will these wheels fit?
I have a '99 C4 with 7.5mm spacers up front and 15mm spacers in the rear.
Fronts:8.5 x 18, ET 52, 235/40/18
Rears: 10 x 18, ET 40, 265/40.18
Standard wheels are 8x18 et50, 10x18 et65. The ones your looking at will be tight (particularly the rears), but should fit with a couple of provisos...
1) Rear tyre should be a 35 profile (are you sure it's a 40 profile? That's a Boxster size)
2) You will almost certainly need to have your rear arches rolled
3) You will need to remove the spacers
They will be pretty flush at the rear!
