Fabspeed 996 Product Suite
Basic Sponsor
Are you looking to increase the sportscar sound and performance of your 996 Carrera
Fabspeed offers a full line of Dyno proven performance products that is sure to give you exactly what you are looking for, whether you want to concentrate on maximum track-competition performance, street use, or a blend of both.
No matter which direction you go, performance optimization starts with the headers. Our Porsche 996 Carrera Sport Headers improve exhaust flow for a power increase of +15 WHP, +12 ft/lbs. of TQ and significant increase in sports car sound. Our Sport Headers feature a 3-into-1 high velocity Formula 1 Indy car style merge collectors for improved exhaust scavenging and increased exhaust flow. Fabspeed’s 996 headers have been engineered and Dyno tested to verify maximum power and are a direct bolt-on replacement for factory OEM headers with no cutting or welding required.
The Porsche factory catalytic converters on your 996 Carrera are the most restrictive elements of the entire OEM exhaust system. There are four catalytic convertors on each and every 996 out of the factory. Fabspeed’s Porsche 996 Carrera Sport Cat X-Pipe is a simple way to significantly improve sportscar sound, performance and save weight without triggering a CEL. Our Sport Cat X-Pipe directly replaces the restrictive four OEM factory catalytic converters with high-flow, German imported 200 cell HJS catalytic cores which flow 93-95% of a straight pipe, with NO CEL! It increases WHP by +25, TQ by +32 ft/lbs. and saves 11 lbs. compared to the dense, 700 CPSI factory cores. Constructed from high-quality .065" thick C.N.C. mandrel-bent T304L stainless steel for optimum flow and maximum durability, our X-Pipe provides a significant improvement to sound, with a throatier, deeper exhaust note; a perfect exhaust upgrade for your Carrera.
For those who want maximum performance gains on a track-only build, our X-Pipe is also available in a catbypass version which adds +33 WHP, +41 ft/lbs. of TQ, and saves 25 lbs. from the rear of any 996.
We offer two options to replace the restrictive, factory 996 mufflers; the world famous Maxflo Performance Exhaust and our much more aggressive Supercup Performance Exhaust.
The Maxflo Performance Exhaust System is a catback system which improves the exhaust flow and the overall power while providing a deep and throaty sports car sound throughout the RPM range. Like most Fabspeed exhaust products, this system is constructed from high-quality 14-16ga CNC mandrel-bent T304L stainless steel for optimum flow and maximum durability and adds performance gains of +12 WHP and +10 ft/lbs. of TQ while saving 7 lbs. compared to OEM.
For those who want a lightweight and more aggressive sounding system, we have our Supercup Performance Exhaust, which adds +8 WHP, +16 ft/lbs. of TQ, and saves 14 lbs. off the rear of the vehicle compared to the bulky factory mufflers. The Supercup system replaces the restrictive factory mufflers with a free-flowing resonated design, dramatically reducing back pressure and significantly adding sports car sound. Just like our Maxflo option, the Supercup is constructed using T304L stainless steel for optimal durability and is backed by our Fabspeed Limited Lifetime Warranty.
Lastly, the restrictive 996 Carrera factory airbox should be replaced by Fabspeed's Carbon Fiber Competition Intake System which increases air flow into the engine for better power and it sounds AMAZING! The competition air intake fits all 996 Carreras.
Now that you have more exhaust gasses leaving the engine, you need to get more air in! The OEM 996 Carrera airbox is good, but Porsche intentionally made it quiet and restrictive. Imagine breathing through your nose when it’s clogged.
Our Porsche 996 Carrera Carbon Fiber Competition Air Intake System opens the engine up by greatly increasing the surface area of air filter with our unique duel inlet system. This improves cold air induction into the engine which increases power and sound throughout the rpm range. Constructed with genuine carbon fiber for strength and durability, our Intake system adds +24 WHP, +19 ft/lbs. of TQ, and saves 4 lbs. This is a direct bolt-on replacement for the factory air inbox; specify if you have the Tiptronic Transmission or X51 Models as they include an additional breather filter and hose for the factory PCV connection.
For 98-99 models, we have our Porsche 996 Carrera Cold Air Upgrade Kit, which we always recommend pairing with a BMC F1 Air Filter. Our Upgrade Kit improves power and sound by increasing cold air flow the engine by 20%, when used in conjunction with the BMC F1 Filter, adding +12 WHP and +10 ft/lbs. of TQ. This is a simple DIY installation that can be performed in under 30 minutes, yet it is significant enough to be used by professional Grand Am race teams in series that require a factory airbox.
Now that you have more air entering and exhaust gases exiting the 996 flat six, all of these upgrades are then optimized by the Fabspeed ECU Tune which re-maps the timing, air-fuel ratios, and more to take full advantage of the upgraded components. Fabspeed Motorsport offers an alternative tuning method for vehicles equipped with ECU's that traditionally required bench flashing. No longer do you need to remove your Carrera's ECU and mail it in for a tune. We offer a MyGenius handheld device that interfaces with the OBD-II port on your Carrera and your computer to complete the tuning process right at home. With just our ECU tune alone, you can expect maximum power gains of 24 whp and 20 ft-lbs of torque at 6300 RPM without sacrificing drivability! ECU Tune is highly recommended if you get the Catbypass X-Pipe option.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
For a 2003 completely stock with Tiptronic, if I got the Sport Headers, Sport Cat X-Pipe, and Maxflo Performance Exhaust, what would be the total HP and Torque gain if I got your ECU tune?
And how much for all this?
Basic Sponsor
Hello All,
The price depends on what parts you actually choose. There are multiple intake parts on here and multiple mufflers on here as well which the price can vary significantly. If you would like I would be glad to set a package up and pm you.
Basic Sponsor
We also are starting a group buy for the 996 and 997 Maxflos. We are offering 15% off if we get 5 or more orders.
On a manual car no problems with the performance mods.
