Oil Pressure
8th Gear
Oil Pressure
Hi Guys,
I'm a new owner of a 1998 911/996. - Absolutely love it o bits. Had it for a while now and had no problems. However, i've been doing a few more KM's and my engine this morning was over heating and the oil pressure is up to 4.5? I'm about 2 weeks out from a service.
I assume it needs more oil and to check this? However my question is do i need to check anything else to make sure i don't damage the engine?
The engine was whining and heat/smoke was coming from the back. Drove it about 100m then put it back in the garage.
Any advice would be amazing as i'm a novice Porsche owner
Thanks in advance RW
Tow it to someone that know what they are doing!
reading this and your other thread.. now hearing about the whining and over heating.. I'm going to bet on the water pump impeller is shot. Was the car idling higher when it was over heating? That would explain the higher oil pressure reading.
Hi Guys,
I would recommend you check the obvious.
1. Drop the oil pan and check the sump for debris. Check the oil pump inlet screen for debris too. Use a magnet. IMS material is ferrous.
2. You may have a faulty water pump. Remove the serpentine belt and check for resistance. Water pumps on these cars can be the cause of more serious damage to these motors. The plastic impellers are well known to break off with age thus blocking coolant transfer thereby causing overheating that lead to cracks which results in intermix.
3. Do a manometer reading on the oil tube to see how the cylinders and AOS are performing.
4. Do you have a Durametric? If so, check camshaft deviations and fuel trim values.
Well, you have 2 ends of the spectrum here.
Based on your "novice Porsche owner" comment I'll make an assumption that dropping the pan and performing any number of advanced diagnosis yourself may be a stretch - I could be VERY wrong though...
That said - have it flat bedded to someone that knows these cars. Likely a water pump.
Overheating and oil pressure up? Whinning? Hmmm any water in oil? Oil in the coolant expansion tank ? If not you may have gotten really lucky! Don't run it. Have it picked up and brought to a shop (hopefully one that's well versed on the M96 watercooled Porsche engine). When you hear what's going on, let us know. Good luck
