996.2 F.C. P0491 P0492
OK, the only time I get these two Faults is after driving to full operating temperature and having to stop at a red light and idling more than a minute and half, both F.C activate, engine stay's running smooth, I reset the F.C. and nothing again till the same thing happens again, never comes on unless at idle for period of time at full temp. any idea's
Thanx Guy's, finally got to work on the car, for the fault codes I started on doing a vacuum test and found a leak from the Changeover valve 1 line going to the Vacuum reservoir. PIA to get too, but done and no other leaks.
Damn it, now it's my turn to trouble shoot this.
I just posted on this problem with an earlier thread, now I find a newer thread. 808Bill, will follow your success with great interest.
So, while this is a PITA to have to watch the CEL and clear codes, is there a risk of damage to the engine by delaying fixing this? I just need to know where to prioritize against other projects.
I have not had to code pop up since I cleared it but I'm ready to tackle it next time it pops up.
Found a vacuum line that was pulled out of a fitting, reconnected it and drove it yesterday without any CEL. It was the line that runs in front of the alternator between the changeover valve #1 and the one-way check valve Bought new hose and "y" and elbow fittings to replace with new. Hopefully no leaks further back and i can avoid pulling the alternator/throttle body. Sounds like a good preventative for a later day.
