Lost front lights
Lost front lights
On a cruise today, I had a fairly large pothole with my front passenger wheel. The dash speaker actually popped up. My highbeam light indicator is flickering on and off in the instrument cluster and I’ve lost all front lights – headlights turn signals etc.
Any thoughts?
Any thoughts?
Im guessing u have a loose harness plug somewhere. Got to start pulling gently on stuff to see if u can replicate the issue. Also double check the headlight switch. They r know to go bad often.
Any damage to the wheel?
Yup, I pulled the lights and popped back and they work perfectly!
i didn’t know that when you put the headlights in, you turn the tool to lock them. So they were in tight by hand but not locked so they jarred loose a tad.
Glad it worked out for you.
Did you buy the car with headlights not locked in place?
