996 Forum 1999-2005
Rear tires gone in 1,500 miles
Old 09-18-2018, 09:45 AM
  #31
Gadsby
Gadsby's Avatar
ding
Nice shave
Skived on wheel well lip
Result of toe change.
The trust arm keeps the control arm in the correct orientation which is perpendiculat to control arm mount, the rear toe link fixes toe position relative to the control arm. Under load the tortion arm can allow deflection of the bushing in both the thrust arm and control arms both bushings. Solid toe links allow no rotation tword the rear.
As you can see from this image worn thrust arm bushings can allow the wheel to rotate to an extreme (toe in) position when highly loaded. The ding in the arm is from the inside wheel rim lip, there were multiple dings in the rim, i caught it just as i installed new tires where it skived the outer edge in the wheel lip which can only occur through excess wheel movement laterally.
You'll find it, somethings wrong which changes wheel travel orientation. Focus in under load not static.
Old 09-18-2018, 11:34 AM
  #32
ttt123
ttt123's Avatar
I'm in a 911 now but two summers ago with my boxster I went through a set of rears in one summer. took it in and had the alignment gone through by someone WHO KNEW HOW TO DO IT and it was bad. new tires and new alignment and it felt like a new car. handled much better, drove smoother, straighter etc.
just contributing about my experience.
Old 09-18-2018, 11:56 AM
  #33
bbboomer67
bbboomer67's Avatar
This is what the blown tire looks like:
That's one ugly tire!
Sure looks like one side wore faster than the other. The second rear tire is still on the car, and it appeared to be evenly worn. I may be able the see that tire off the car later today.
Gadsby: this does not look to me like the kind of wear you experienced.
​​​​​​​ttt123: Hopefully the car will get towed to the shop tomorrow, and we will have more info about the alignment and suspension.
Old 09-18-2018, 11:57 AM
  #34
ttt123
ttt123's Avatar
hope it gets figure out for you.
Old 09-18-2018, 12:50 PM
  #35
Gadsby
Gadsby's Avatar
Pretty consistent: check how much camber and toe?
Old 09-18-2018, 01:43 PM
  #36
808Bill
808Bill's Avatar
Old 09-18-2018, 02:11 PM
  #37
USNA1970
USNA1970's Avatar
My alignment was a little off after replacing my front lower control arms. In 2000 miles my inside shoulders were toast. Since then I have new tires with 7k miles and they still look new. You might be surprised how fast a poor alignment will ruin your tires. In my case the toe was equally pointed out, so I didn't feel much pull unless one wheel was more or less loaded than the other.
Old 09-19-2018, 07:49 AM
  #38
bbboomer67
bbboomer67's Avatar
My car is now at the shop where the suspension will be examined before getting a new alignment. The old rear tires will be shipped off today to Tire Rack for their examination.
One thing I noticed yesterday as the car was sitting on the tow truck is that the exhaust tips seemed to be lower than usual...maybe an inch of gap. I understand that may indicate aging motor mounts. Would that have any impact on extreme tire wear?
Old 09-19-2018, 09:28 AM
  #39
Gadsby
Gadsby's Avatar
Worn motormounts will have the movot moving pretty free in the back which would feel like the motor setting after the car sets in a corner, kind of like a thud.this is also what the engine actually hangs from, easy to check and change. Each one is 3 bolts.check tranny mount while your at it but should have no plausable effect on what you experienced.
i included a pic of solids and semi solid kounts. I run solids for the track but are very loud inside.
Old 09-19-2018, 09:30 AM
  #40
Horsepwr
Horsepwr's Avatar
All this alignment talk, I am curious as to what you guys are paying for one? Im thinking this might be a dealer only situation, Im guessing a place like Town Fair Tire isn't going to do it properly lol.
Old 09-19-2018, 09:40 AM
  #41
De Jeeper
De Jeeper's Avatar
Received 3,276 Likes on 1,709 Posts
Mine cost $130 for a weighted 4 wheel alignment in Delaware. Its a local shop that asked the most important question.... "how do u plan to drive the car?" If u want it set staight to factory spec anyone can do it. If u want it to perform based on upgrades u need an indy with porsche experience.
Old 09-19-2018, 09:41 AM
  #42
Horsepwr
Horsepwr's Avatar
Old 09-19-2018, 09:50 AM
  #43
cds72911
cds72911's Avatar
I cant imagine how worn motor mounts could result in accellerated tire wear.
They’re easy to swap out though.
Old 09-19-2018, 10:07 AM
  #44
bbboomer67
bbboomer67's Avatar
Originally Posted by cds72911
I cant imagine how worm motor mounts could result in accellerated tire wear.
Thanks...another winter project!
Old 09-19-2018, 01:34 PM
  #45
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
I just paid $179 for my alignment at the local Goodyear place close to my home.
It was set to stock settings for now.
Motor mounts are probably a 30-45 minute job.
I need to do my own.
I want to go with Rennline motor mounts since I installed a set on Monday.
They're REALLY nice.
The semi-solid ones are tunable.
Quick Reply: Rear tires gone in 1,500 miles
