Rear tires gone in 1,500 miles
How is it even possible that my new rear tires, Continental Extreme Contact Sport, would be gone and down to the cords in 1,532 miles. The fronts look fine. One rear went flat. I swapped it for the mini spare, which was not fully inflated and only lasted a couple of miles before shredding...had to get a tow. I had the wheels aligned this spring after having the rear control arms replaced on my '02 C2 Cab. A friend said it happened to his Boxster, and it was rear wheel alignment. The wear across the other rear looks even but all tread is gone...a slick. Any thoughts about culprits other than rear wheel alignment? New Michelins on order...an expensive summer for tires!
Alignment, rear wheel drifting, tire spin?
Either your are burning rubber up and down the road, or your alignment in way the hell off. Is it possible you have another person in your home who may be taking the car for a joy ride here and there and showing off by peeling out all over the place?
I'm a sedate 72 year old who only occasionally is heavy on the gas. I don't burn rubber, and no one else drives the car. I do like corners but have not abused this car in any way. Gotta be the alignment failed, eccentric bolts loosened, something like that. I did have an issue once after the car was up on a lift...the eccentric on the left rear loosened by itself, and the car was scary to drive! Maybe Loctite those alignment bolts?
BTW I love the color!
Received 5,388 Likes
I am running the same tires since January 2018. They have performed well and still look very good, I've put over 7,000 miles on them. I would be contacting the place I bought them from and Continental directly. Your wear experience is super a-typical.
As others have said. Correct Tire pressure is very important as is the alignment. Periodically check the spare as it's useless if not full.
They do make locking plates for your eccentric bolts. I'd get new ones. I suspect the last place that did your alignment never torque them properly...
Wow, I didn't read the manual about flat rear tires so I didn't know this. I would have had to think to jack the front first and swap the space saver there before lifting the rear. I'll know for next time. I was only going 25mph with the space saver on the rear, but there is a lot more weight on the rear than the front!
I'm betting on an alignment issue...pressures were good. I'd rather believe in defective rubber but find that hard to believe. I will contact Continental.
Rear tires also didn't last as long as the fronts. About half as long. Sticky rear performance tires are good for about 3 hours of track time.
