Oil in Cylinders
Oil in Cylinders
Oil pool in cylinder 4 after having a borescope done, 5&6 have oil towards the head
Cylinders 1,2,3 look pretty normal
Very small amount of smoke at start up but not all the time
100-200 ml of oil every 600 miles
No CEL or noises
Cylinder 4,5,6 relined 20k miles ago after found to have had bore scoring
No evidence of AOS being changed
101k miles
Anyone seen similar condition of cylinders?
No CEL or noises
101k miles
If you had your engine re-sleeved with iron or steel liners they have a different thermal expansion rate than aluminum, hence I believe they require a larger piston to cylinder clearance.
Its one of the reasons Porsche try and match piston to cylinder material expansion to keep this tight, reduce emissions and oil consumption.
It might be normal but I'm sure an expert will comment soon
7th Gear
Oily combustion chamber
No CEL or noises
101k miles
No CEL or noises
101k miles
Received 1,902 Likes
I just borescoped my engine which has about 15k kms post rebuild. I have been burning a lot of oil but i have attributed it to the AOS. My cylinders look like yours from the spark plug holes and there is a lot of carbon on the pistons from the burnt oil. From the sump i can see a pool of oil behind the piston which the rings seem to be largely holding back from the combustion chamber. You should measure AOS health with a vacuum manometer.
What type of rebuild did you do. Nik'd alum or steel..?
Charles of LN Engineering stated that the non-Porsche piston rings are not keyed to the pistons so that the ring gaps can turn and end up where the oil would leak to the combustion chamber. That is one reason why a LNE rebuild can consume oil.
7th Gear
allcool (06-19-2024)
7th Gear
I am replacing them to rule it out. They were cleaned and tested. For every other car that is sufficient but for m96 engines everyone says to junk them. I'll have new ones in shortly.
Do you have a link to confirm this?
BTW : Anyone who has oil pooling in the combustion chamber or intake should ( first) test the AOS Health ( second ) Test the Engine Health / blow-by ( I don't care if it a newly rebuilt engine with cylinders/rings/pistons and only 10k miles, test it )
damage98MO (06-21-2024)
