996 Forum 1999-2005
Driver side power window
Old Aug 17, 2018 | 06:17 PM
myronf's Avatar
myronf
Default Driver side power window
Every once in awhile, my driver window does not go down when I acticate the pw switch. I have always gotten it to go by cycling the switch from up to down to up to down. Is the sticking in the upper weatherstripping? Or is it something more serious. Where do I start looking?
Thanks in advance
Myron
Old Aug 19, 2018 | 01:05 PM
Mike Murphy's Avatar
Mike Murphy
Probably the motor has a dead spot on it. You can test the switch easily by pulling the 2 switches out and swapping them. Leave it that way and if the problem moves to the other door, the switch is bad.
If you listen closely, you can hear the motor (and see a voltage drop on your voltage gauge) when you click the switch. If you can hear the motor and see the voltage drop, then something is locking up the motor. If you cannot hear the motor or see any voltage drop, then the motor is likely sudfering from a dead spot.
If the problem remains, I would buy a new window regulator assembly, or send yours in to have it refurbished (there’s a shop in Phoenix, AZ that does several Porsche regulators per week). It’s sometimes cheaper to have the regulator rebuilt with arguably newer, stronger, parts.
Old Aug 20, 2018 | 06:07 PM
myronf's Avatar
myronf
Thanks for the reply. I will follow your suggestions.
Myron
