Manual transmission oil drain plug washer. Is there one?
Unscrewed both the drain and fill plug today but noticed no gasket or crush washer. Is there supposed to be one? I could not find any parts numbers at Pelican or elsewhere. I also read that one could use the oil drain plug washer?
Pelican lists a washer but I did not order one. Just used the same fill and drain plugs and tightened until they won't tighten anymore. No leaks.
I guess tightening it to proper torque (20 ft-lb.) would be the right thing to do. Over torquing the plug could induce stresses in the casing that could cause damage later on. Also, plug seemed like a harder material, so the internal threads of the casing could start yielding if you go over the limit.
