okay, so younpeob remember I ended up breaking the rear passenger window. So a new window came in the mail... I tried youtubing and googling it, but can't seem to find out to change it out. So does anyone know how to change out the window and keep everything waterproof?
I would go to a shop that installs windshields. It was probably installed with a bead of sealant around the edge.
If it is harder to install than it is to remove, I would also suggest getting a professional to do it. Removing them was a bear, as they sit in a channel with a rubber gasket, that channel is riveted in, also the trim around it is a huge pain. I also could not find a DIY. Since I was parting out the car, I didn't care if I ruined anything since all I wanted was the windows.
BTW, if you have not gotten a new window yet, I have both sides available for cheap.
