Oil pump replacement
hi all
is it necessary to remove all 3 chain tensioners before removing the oil pump (main pump) or is it enough just to remove the bank 2 tensioner?
So, was the pump damaged? I had mine out this winter, they are pretty robust. I think I'd be checking filter and dropping sump. If you find anything there, pull the transmission and check that IMS.
I too would like to see what a damaged oil pump looks like. Have you dropped the sump and inspected your oil filter?
As others have said IMSB would be my main concern!
Then the rattling must be something else. Are you sure it's coming from the pump, maybe a pulley bearing? Lets us know what you find.
Glad to hear it's all good to go.
