trya pic
David,
Are you sure you are uploading your image?
1- You must first upload an image from your pc. To do this, click on 'Upload Photo' after which you must enter some self info for the servers to recognize you as a rennlist member
2- Once you upload an image, the same image is displayed on the explorer window. Under it is a url, a web link that you should roll your mouse over to be able to copy (right click-copy)
3- Having done that, go to the chosen post you want to add your image into, click on ''reply post''
4- You then have a reply window above which are a series of clicks and icons
5- Click on the 'IMG' grey square and a small window will open
6- You now have to paste the URL you previously copied inside this window (make sure you erase the 'http://' words before doing this. Click OK and the URL to post the picture will be shown on the reply window itself
You now can post a picture..
Phew!
Waz
Phew!
Waz
Phew is right Waz. Thank you. I apparently was not a member, just registered. I just joined and should have a # by e-mail tomorrow. Then I should be able tio upload. Thanks again, everyone
