Radiator screens?
#31
Here is a link that may help some, not mine but I used it to make my grills. - $300 for $20 of materials was to excessive for me!
I used black aluminium mesh, pulled the bumper, made templates out of cardboard, cut the mesh to suit the cardboard, finessed where required and bonded into place.
http://www.cumbriacarstorage.co.uk/p..._996_mesh.html
#32
Shameful Thread Killer
I'm going to do the screen next month. So, don't feel bad, you're not alone. You will also love the third rad. Hope you put in the 160F thermo at the same time. I can sit in hot traffic with the AC on high and not worry a bit. It's a great feature.
#33
Inside:
#34
Evil Bunny,
I was looking at your DYI mesh application. 1) I understand I will need to use Master Seal to bond the mesh to the inside of my bumper2) What was that black strip you wrapped around the ends/edges of the mesh that I assumed you used when bonding?3) or am I over thinking this?
MNC-I
MNC-I
#36
You don’t need glue or edging. The screen is jammed between the bumper and the plastic/rubber ducting. I put two short screws per side to hold them in place so they stay until the bumper is installed.
Here is what was in the ducts before install:
#37
Wow. What did it look like behind the condensers?
#38
She was running a little warm...
#39
Yeah I did the 160F thermo last year when I replace the engine. Hoping this helps my track day temps which can get pretty hot.
#41
Also question for anyone that did the DIY. Can you circle on one of your images where the screws are? Looking at the pictures, I do not see an screws, but knowing how thin the bumper is, I don't know how that could be possible. Or is there another layer of bumper that I am forgetting about?
I screwed it into the thicker part of the black surround that is inside the bumper itself, not the thin bumper skin. It is really the ducts that hold them in place.
#42
