Engine Out Whatelse Needs to be Replaced
I’m having my engine rebuilt. While the engine is out I intend on:
This is what the shop is doing:
MB Motorsports will install: new main bearings, new rod bearings, new piston rings, new updated IMS roller bearing, new water pump, new updated low temp thermostat, new timing chains, new sliders, new tensioners, new seals, new gaskets, both cylinder heads will be professionally fully restored(sanded, resurfaced, serviced valves, new seals, pressure check), new rear main seal, new filter, new cylinder head bolts. If cylinder heads are not repairable they will be replaced.
Block will be resleeved with steel sleeve technology which completely eliminates scoring, d chunk and cracking issues for good. Our resleeved cylinders come with 5 year warranty. If anything should happen to cylinders during those 5 years MB Motorsports will repair the problem at our cost.
2003 - 996 - 87k on the clock - I’ve owned less than six months - don’t think maintenance was done as needed by previous owner. I plan on keeping this car for years to come.
911STYL
- Replacing clutch - dealer recommended
- AOS
- Motor mounts
- Transmission mounts
911STYL
Well I guess it really depends on how deep in the rabbit hole of the wallet you are willing to go and what needs to be done versus what you would like to have done. Sound like a lot of nice work is going to be done to your car BTW, it sounds like you will have a trouble free 996 motor for a good while. I too did the roller EPS bearing when I changed mine out. I actually also replaced all the plastic stuff inside the motor as a refresh and some stuff on the outside that I knew I would not have access to being that my car is a "00" so there was 17 year old stuff in there that would crack at the mere touch due to the cycle of heat and cool down. (little clips,connectors and plugs) On the serious side, since the motor is out you could change the coolant reservoir specially if its old and yellow. You are gonna have a nicely refresh motor in there so might as well make the engine compartment look good. I replaced my firewall too because the black "Porsche' original foam stuff on mine was aged and sagging, tore that stuff out and got a new firewall.
It's a great time to refresh rubber hoses and vacuum lines. Also, the dual mass flywheel has to come out, so depending on the depth of your wallet, replace it (LUK is OE supplier), throwout bearing, etc. I'd also do all the little stuff in there - transmission input seal, for example.
You are already deep into the rabbit hole with the engine rebuild but with the engine out I would do everything I could that is significantly easier with the engine out. Since you are trusting MB Motorsports with such a big job, you should ask them to inform you of any parts they recommend replacing.
I would definitely do ARP rods bolts.
I have a MB rebuild engine, done in 2015. I can tell you for sure that it was not re-sleeved. The water-pump that was in it was not a 996 water pump. The IMS bearing was a roller bearing, but frankly I wouldn't trust it to last any longer than the stock bearing.
If I had the engine out I would also replace:
1. Spark plugs and coils
2. oil filler neck
2. oil filler neck
Replace or have your injectors rebuilt/checked. FSI claim they are seeing lots of leaky injectors causing bore washing.
I might be completely wrong about this, but MB motorsports might be a vendor with a less than stellar reputation around here, do some searching on here and google to check them out before committing.
Have you priced up getting nikasil or wet ductile liners done instead of dry sleeves? the price difference might not be as much as you think.
911STYL
- AOS
- Motor mounts
911STYL
I'd replace the heat exchanger or at the very least the orings for the exchanger. Bank 2 chain tensioner just because it would be much more difficult if the engine was in the car. The air injector switch, and maybe the vacuum tank. Oil pressure gauge. Coolant reservoir. Metal, Porsche belt tensioners and pulleys - don’t waste your money on the Continental kit. AOS. Injectors cleaned or replaced. As mentioned, water pump.
GOAL: In conjunction with the engine rebuild, I have several major upgrades that I’m traveling down a dollars and sense rabbit hole at a high rate of speed. At the end of the day, the car will be road worthy for many years to come, speaks to my style and has great throttle response.
ENGINE OUT PURCHASES:
SPEED:
INTERIOR: I also customized the interior significantly. Some of you are gonna love it and some of you are going to say it’s an abomination – LOL. I love how you guys say something is screwed up but then soften it with “but it’s your car – do what you want to do” LOL. So be kind when I post pics.
EXTERIOR: LED tail lights, HID headlights, LED third brake lights, new rims, painted calipers, on the fence about some decals and some other stuff.
SUSPENSION: Suspension is being upgraded as well. I’ve purchased some Ceika coilovers and a bunch of TRW suspension parts to lower and manage ride.
Making this 996 mine
- Fister D Exhaust
- OBX Headers
- Starter
- AOS
- Oil Filler Tube
- Water Pump
- Coolant Expansion Tank
- Coil Packs and Plugs
- Clutch Kit – expensive
o DMF Flywheel
o Pressure Plate
o Clutch Disc
o Release Bearing
o Pilot Bearing
o Pressure Plate
o Clutch Disc
o Release Bearing
o Pilot Bearing
- Motor Mount – Function First $$$
- Tranny Inserts Orange – Function First
- Hoses
- Is there anything else that is needed?
SPEED:
- Fabspeed CAI
- GT3 Plenum – on the fence for this one
- ECU Tune
- Dyno – I don’t know if both ECU and Dyno are needed to tie everything together.Can someone straighten me out on this one?
1. Long story made short - car was driven for a month with very low oil level. Smoke on startup. Tapping noise as well.
2. Dealer takes a look and gave me a $32,000.00 estimate. Engine needs to be replaced or rebuilt.
3. Wanted to keep the car so I went the rebuilt route.
I don't know what MB replaces, but I would insist on new rod bushings. The bigger question is what are you doing with the heads? I'd look for a shop that will replace the guides and recut the valve seats. Be careful though, I don't believe the seats were designed to be cut so you need to find someone who knows what he is doing. If you do this, you should get the spring pressures measured to see if you need shims for the valve springs. If you have a budget for another $1,000, then new valves and springs.
