Another IMS question (Replace LN Retrofit?)
There have been zero failures of the Single Row Pro or Classic Dual Row Retrofit kits. Likewise, the IMS Solution also has a flawless record. That said, there are Classic Single Row bearings that have been in service now 10 years, well past the recommended service interval. As with any mechanical part, the longer it is in service, the greater the likelihood that it will wear out or fail. There is a reason why manufacturers recommend timing belts on those engines where it is not a permanent chain - some at 60k, some at 100k. The idea is you change it before it fails.
1 "There have been zero failures of the Single Row Pro or Classic Dual Row Retrofit kits"
2 "Any part supplier that says they don't have failures is straight up lying"
A paradox:-(
Not that I want to get in the middle of this debate...but I think you have to look at what Charles has said (I am not an attorney either)...He has stated that they recommend regular maintenance and replacement every 4 years. But what he also said that of the two types he lists there have been no reported failures. He is not stating that they wont fail, just that they know of no failures. Those are two different things. :-)
'There have been zero failures of the Single Row Pro or Classic Dual Row Retrofit kits. Likewise, the IMS Solution also has a flawless record.'
There are many who wait until they see debris and then sell their car to some poor unsuspecting soul who has a live grenade on their hands.
Russ, how is this a paradox? You are not adding anything constructive to this conversation by being a horses a**. There have been many threads on this topic prior to your joining Rennlist. The search feature is your friend. I've been honest about failures and there have been members with failures that have posted on Rennlist previously.
A paradox is a statement that contradicts itself and still seems true somehow.
It is because of people like you that I took an extended hiatus from the forums.
Received 1,092 Likes
Charles - you provide invaluable technical knowledge and information and I appreciate it. As do so many others on here. If you have to step away from this one...do so, but please stay with us as we really do appreciate everything you provide, and your company provides. Proud owner of many LN Engineering products!
8% of cars fail at an average of say 85,000 miles remember some never fail in the life of a car even 250k or more ;
so you take 100 cars do 85,000 miles in each so you cover 8,500,000 miles divided by your 8% or 8 failures = 1,062,000 miles traveled
( I am not nor have I implied that 1 bearing would or could do this, what I am pointing out is on average (as I have stated many times) A 996 single row bearing will go every aprox million miles travelled)
This is not taking into account the 1% for the upgraded bearing which has a failure rate of 1 in 8,000,000 miles travelled.
Anyway I'll agree to mention it to you no more, if you agree when I give someone advice on IMSB you don't reply to me.
As you have an agenda, but to me it's a bit of number crunching unbiased advice to someone who asked,
It's just the way you word thing implying the original IMSB will fail when it's chance of failure below
This isn't a made up problem and your opinion is no consolation for those who have suffered a failure or multiple failures.
you say my data if flawed, let"s see your data to the contrary.
I doubt you'll reply but I hope you do, if you have data to the contrary when someone asks again I can say here you are I got this from Charles he knows what hes talking about, if it's fact based I'll back yiou all the way.
best wishes Russell
There are lies, damn lies...and statistics. Here's a point of bias for you - Charles, Jake and LN Engineering know more about this problem than anyone, and have developed, marketed and installed solutions with recommended service life based on their knowledge - 4 years or 50K miles. The OP has already had a single row retrofit, so any debate about original bearing life is moot. What is relevant is the 4 year/50K service recommendation for a retrofitted single row bearing. The OP I think checked out of this thread...but if he is still checking in - For your peace of mind, schedule to have the bearing replaced and spring for the Solution...then drive it like you stole it! It will be worth it if you plan on keeping the car.
Ps I have never doubted the ability of any mechanic on this site
