Acceleration to redline is not smooth
I fixed it.......More like I caused it and THEN fixed it.
When I modified my airbox to remove the resonator (you know, the closed box hooked to the tube just ABOVE the MAF) I did not block it off. Thus the engine was taking in air PAST the MAF causing issues.
I should have known better but missed it. OOPS! Live and learn.
Well, this evening I pushed the PCar hard against another car
But what I noticed was the power was not smooth thru the acceleration. The best way I can explain it was a surge or loss of power momentarily at several points during acceleration. THis was in every gear.
I have a B&M Air filter in the car. But that is all.
The car came from NY to Denver. Thus a 5280ft gain. I know is SHOULD adjust but I am not sure.
Any suggestions?
Thanks.
I think the more you read, the more you will hear this complaint. I've seen many posts of the like and too have experienced the same dips and surges in acceleration. The car is still fast as F#$% though, right?
My 996 is smooth and very linear. It is an 04 though with only 1,600 + miles on it. I have felt surge areas in the TT. Not bad, but a few here and there even after lag.
I had lags here and there in my 964 until I got the top end rebuilt . . .
Recently I experienced a similar scenario where the car felt like it didn't want to push at around 5K RPM. The check engine light then came on, and the mechanic told me that it was the mass air flow sensor that needed to be replaced.
Sure enough, after the job was done (and a couple of days for it to regulate itself), the car accelerated like it did when I first got it.
I really do not hink it is the limiter. It is happening way before that. It is just odd.
I had to replace the battery the other day and thus had power off the ECU for a while. To my understanding that should have reset any adaptive values. But that is based on my BMW knowledge.
Originally posted by Tim Wasmer
VERIOCAM? New to Porsche, what is that?
Sorry for the dumb Q.
Originally posted by Speed
I don't think the '99s had Variocam. I believe it was introduced in '02. I had a '99 C2 cab and traded it in for an '02 and there is a difference. With the '02 there is a little bit of a surge at about 3,200 rpm.
