996 Forum 1999-2005
Bose Failure (03 C2)?
Old Dec 23, 2003 | 07:46 PM
winovin's Avatar
winovin
Default Bose Failure (03 C2)?
My 03 Bose does not output any sounds - head unit seems to be working.
I recall this problem, but a search did not get me any hits in the archive - what is the cause and cure?
Thanks,
wino
Old Dec 23, 2003 | 09:48 PM
Davidmichael's Avatar
Davidmichael
Default Bose
Turn key off, get out, lock and unlock car. May work. Also, could you have muted it by mistake?
Old Dec 23, 2003 | 11:58 PM
winovin's Avatar
winovin
I will try that tomorrow - definitely did not mute it. I tried switching off car and restarting a couple of times, switching stereo on and off.
Old Jan 5, 2004 | 05:34 PM
Dr. T's Avatar
Dr. T
This morning my 2003 TT did the same thing. Error message was "unable to communicate with amplifier". I fixed it by pulling and reinserting the "sound system" fuse. I think it was D9 in the fuse panel.
-Glen
Old Jan 5, 2004 | 05:49 PM
Photon's Avatar
Photon
Wino,
I had the same experience with my 2003 C2. The problem happened several times on different occasions and then one day nothing worked. My dealer replaced the head unit. I have had no problems since. Since it is under warranty I suggest a trip to the dealer for replacement. You really do not want an intermittent problem.
Old Jan 5, 2004 | 05:57 PM
cvuplay's Avatar
cvuplay
There's is a service advisory for '03 radios. If your car falls within a VIN range, Porsche will replace your head unit. I had my done a few weeks ago when I took it in for my 15K service. The unit was malfunctioning for a day or so, early last year, but worked fine prior to its replacement. Because my car was within the VIN range that had the "faulty" radios, the dealer went ahead and replaced it under a recall warranty.
