Installed a 997 GT3 Master Cylinder in my 996 C2
#121
So maybe this is a dumb question, and if it is, forgive me. I'm getting ready to do brake lines and the GT3 MC on my 03 C2 w/o PSM. It sounds like I shouldn't have issues with lights etc., but my concern is the bleeding process. Will I be able to bleed the brakes with my pressure bleeder like normal after this, or will I have to track down someone with PIWIS or Durametric to enter some kind of bleed mode for the ABS pump, etc?
#122
Undo the lines at the MC and plug them to make sure the ABS hydraulic unit doesn't lose the brake fluid inside it, then standard bleeding will work (as in no necessity to switch any valves inside the ABS or run the ABS pump to bleed the system).
khyatt (01-19-2023)
#124
If you enlarge the master piston diameter, the pressure is reduced and causes you to have to push harder for the same friction right? Why would you do this?
And sure the pedal would travel less and have a solid feel
#125
2. A firmer pedal that may degrade some over hard use provides better feedback of the drop off that is occurring (for me)
3. A firmer pedal allows a finer degree of modulation under hard use when inputs are generally stronger (for me)
Going to the GT3 master is right up there with the best modifications I have made for track use.
dougn (01-20-2023)
dougn (01-20-2023)
#127
dougn (01-20-2023)
#129
Im using all 4 gt3 uprights and front caliper gt3 6 pots. In the rear im using c2 front calipers instead of the gt3 caliper (more piston area).
Zbomb is using 997gt3 calipers with adaptors.
If u do the math for the front and back bias the set ups r the same ratio but my pistons r larger (front and rear) so i get 30% more force.
The following 2 users liked this post by De Jeeper:
dougn (01-20-2023),
Porschetech3 (01-20-2023)
#130
Found the difference between GT3 and PSM Master Cylinder
In case anyone still follows this, the difference is additional flow restriction in the flow path to the reservoir in the plunger in the PSM MC. The flow restriction has some spring and needle valve in it and it restricts flow significantly compared to the GT3 (I can blow in each.) For info i destructively removed the valve. See below, GT3 on top. No way to swap parts, they are all punched and pressed on. This is why the Flewis solution works, but it has the downside of restricting flow going out of the MC to the front brakes also.
#131
Edit: Maybe I am wrong but I thought with PSM the secondary circuit is being used for that. And that it was applied to all four wheels.
#132
Proportion Valve
https://shop.wilwood.com/blogs/news/...ing-valve-work
#133
Thanks, I believe I had seen this when I put it in about 100 track days ago. I guess I should get around to installing that brake pressure sensor and see what I'm generating. Stock 996 is really a momentum car now so I would be surprised if it's that high under normal laps.
So the rear brakes are not engaged by the PSM?
#134
From a BMW MC, but works the same as 996.
zbomb (07-02-2024)
