Porsche remanufactured short blocks
#46
Thankx !! Good info !!
#48
996 100 996 TX:
Short engine
Comprising:
Crankcase
Connecting rod
crankshaft
Oil pump
Timing chain
Partks kit
without Gaskets
Use also:
99610101600
99610421554
99610622352
00004320435
00004330013
90037813100
99917020791
Almost 20k AUD...
There is one replacement engine available: 996 100 996 29 - $70k AUD!
#52
Spot on. The shortblock is the same as the non X-51 models, with exception that it probably comes with the x51 oil baffle rather than the normal plastic one.
#53
Here is whats in the PET:
996 100 996 TX:
Short engine
Comprising:
Crankcase
Connecting rod
crankshaft
Oil pump
Timing chain
Partks kit
without Gaskets
Use also:
99610101600
99610421554
99610622352
00004320435
00004330013
90037813100
99917020791
Almost 20k AUD...
996 100 996 TX:
Short engine
Comprising:
Crankcase
Connecting rod
crankshaft
Oil pump
Timing chain
Partks kit
without Gaskets
Use also:
99610101600
99610421554
99610622352
00004320435
00004330013
90037813100
99917020791
Almost 20k AUD...
#54
#55
Porschetech3 thanks for the info!! My plan right now is to investigate buying a motor or building a 3.8L and putting the existing motor in mothballs. I bought this car to drive it, and for the price of entry, I'm less concerned about buying a motor or building a motor. Knowing about the shortblock options is good. Having driven a 3.8L converted 2000 model 911, I was amazed at the torque and performance of the motor. So I'm really intrigued by this option.
#56
while definitely better than $24k for the motor alone, for those non-diy'ers out there, this $8k shortblock will still be $12k installed, so still not a totally low cost option.
#57
#58
This is true on the 3.6 and 3.8 x51, but the 3.4 x51 kit came with different pistons, also cams, heads, intake, headers, oil pan, and a double scavenge pump on bank 2 head.
#60
I commute to Chantilly every day, an hour. But it’s worth it to me to live in the Wilderness Battlefield and have a private range, and 30X60 shop. I have plenty of space to park both my car trailers and no neighbors to bitch about anything I might do or park outside for extended periods. 32 years commuting up north. 32 years living in the country just outside of Fredericksburg.
