Porsche remanufactured short blocks
Hmmm... I'm looking for a second engine that I can put in a corner of my shop wrapped in plastic. This seems like a good option for a reman shortblock. When I bought my car last week it came with receipts from the seller showing a full "engine out" complete IMS replacement, along with a new upgraded clutch kit. At 64K miles (at the time) I'd hope I have plenty of time before needing one, but I also don't want to not have one available if I need it down the road either.
Subscribed!
Subscribed!
Mikelly,
You know, I was thinking the exact same thing even though my 1999 already has factory reman with the larger non servicable IMS bearing and low mileage. I guess like many of us, we love our "forever" 996's.
From Porsche:
- Genuine Porsche Parts - Come with a 2 year unlimited mileage warranty. All warranty claims must be processed in person at your nearest Porsche Service Center, then inspected on the vehicle by a factory trained Porsche technician. If approved, installation (but not diagnosis) of the replacement part is typically covered.
Does anyone know for sure what exactly the short block contains? I’m going to contact AutoAtlanta tomorrow to find out, as I think their website is confusing at best, and possibly misleading. The picture of the short block appears to me to show only half an engine case. I’m wondering if you need to buy 2 half’s to get a true short block. Also it’s unclear to me if a crankshaft is included.
Edit : that page does still show one variant of the engines (m96.02 3.4) as being availible in a complete plug and play "reman" engine for 11k) you can distinguish the "reman" engines by the part number ending in "X"/
http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=996-99-05§ion=101-00&pn=996100996UX#a
I bought a factory "reman" shortblock for my 2003 3.6. It comes with a lot of parts that you would want to replace in a rebuild.
One thing to note: The block was beautiful, brand new... But the coolant housing that came on it looked oxidized, like it had been sitting on a shelf for a long time. Later on, when I was looking into an unstable oil pressure that ended up being the sender, I pulled out the oil pressure relief piston- it had very peculiar wear like it had been chattering, and had substantial pitting in the exact shape of the passage in the oil pump (where it would be exposed to air).
I replaced it, but am going to pull the pump and look for further signs of corrosion eventually. I worry the steel pump gears will be pitted in the same fashion.
If I were to do it again, I would FOR SURE pull off the oil pump on the brand new short block and confirm conditions before assembly.
Everything else including the price is fantastic- newest factory ims design
Dan951 mind sharing how much you paid? was it as advertised on autoatlanta?
This is all good news. Kind of changes the game for 996 NA imo. Not that it matters to me. I'm in for better or for worse
From Auto Atlanta, this page shows the short block as having cases, crank, pistons, rods, timing chains, oil pump, ect, the things you would expect from a "short block". the price list. 47k for "new" plug and play engine. 23k for "new" short block, and 6k for "reman" short block. (note ; no "reman" long block or complete engine available.
http://www.autoatlanta.com/porsche-p...=996100996UX#a
It is not a new short block for $6500, it is remanufactured .
So I wonder if warranty is same for remanufactured as it is new?
Either way, I don't think I would have spent the money for LN Single Pro on my 60,000 mile 3.6, that showed no signs of IMS or RMS issues. If I knew this was an option, instead of all information claiming $24k
After tear down, the IMS was perfect.
I
Be glad it was , If the ims wasn't perfect , you'd be needing one of those blocks .
having a background in mechanical engineering with aviation and heavy mining equipment experience . There are many components you change when they hit the time and hours numbers . "Run to failure " just isn't a part of the ethos .
its through that lens I view this bearing .
i changed mine with only 35,000 miles on the car . The bearing was in such good shape the seal was still intact with grease in it . No regrets .
i changed the rms, flywheel and clutch at the same time . They looked good .
coming off Italian cars and motorcycles , none of this seems that bad.
So for clarity.
I
I
Seems kinda fishy
