996 Forum 1999-2005
Passenger window doesn't roll down all the way...?
Old 10-03-2017 | 09:39 PM
Luch's Avatar
Luch
Default Passenger window doesn't roll down all the way...?
Just replaced the regulator in my passengers side door...damn thing won't roll down all the way. It does seem like it goes lower a little over time, well since last Friday if that makes any sense?
Curious if there was any mechanical adjustment or if this is something electrical that is required for memory. The adjustments on the regulator itself are minor and I don't think for this application.
New Porsche unit, what a piece of crap...I miss the old style regulators!
Thanks for any help.
Chris
Old 10-03-2017 | 10:22 PM
AWDGuy's Avatar
AWDGuy
Chris
Attachment 1257971
Attachment 1257972
Attachment 1257973
there's a stop/plug on the regulator you need to remove for instalation in a 911
Old 10-03-2017 | 11:45 PM
fpb111's Avatar
fpb111
Look at the picture of the genuine Porsche regulator, green pulleys. There are two yellow stops on the arm. The upper one is for Boxster the lower one, towards the right in the pic, is for 996. You have to remove the upper one for your 996.
http://www.pelicanparts.com/cgi-bin/...erTech%23item2
P12 (07-23-2022)
Old 10-04-2017 | 04:00 AM
Luch's Avatar
Luch
Guys, thanks for the help...so strange but all the documentation I have read on this said nothing about clips to remove so I am really confused! Glad I did not button up everything yet on the car.
FPB111, I looked at the pictures but do not see any yellow stops? I will search for some pictures as I am not sure what you mean...?
Chris
Old 10-04-2017 | 05:02 AM
Luch's Avatar
Luch
Found a video and figured it out...now it seems to easy!
Thanks again.
Old 10-04-2017 | 01:12 PM
6seirralima's Avatar
6seirralima
5th Gear
Fantastic! I had the same issue and was at a dead end.
Old 10-04-2017 | 10:39 PM
Luch's Avatar
Luch
Super easy fix, got it all squared away an hour ago. Pulled out the Bose speaker assembly and got that stupid stopper out!
Thanks for all the help!
Chris
Old 10-06-2017 | 10:39 AM
dporto's Avatar
dporto
Chris
So this is what I was wondering. Can you get the stop out without taking the entire inner membrane out? It seems like you removed the speaker/sub unit and were able to access the stop through that opening...Is this correct? My passenger side window has been like this since I replaced the window over a year ago. As you can tell from the timing, it's not a huge deal for me, but I would like it to be right...
Old 10-06-2017 | 02:59 PM
Luch's Avatar
Luch
Hey Dporto...correct, pull the door skin, fold up the rubber shield underneath and unbolt the four Phillips screws to slide out the speaker assembly. The stop is right there for super easy access. I was dreading the idea of removing everything but after finding some information and pulling that assembly, I knew this was finally an easy fix!
Chris
Old 01-09-2021 | 04:54 PM
nicomedo's Avatar
nicomedo
Hello from Ireland,
I was having this issue until I came across this thread and video on YT
I did this on my 997 passenger window but still no luck. It stops about 1 inch from the bottom.
Am I missing something?
N
Quick Reply: Passenger window doesn't roll down all the way...?
