AOS - Disconnect the cooling circuit
drill out the plastic to fit male to male nipple
If you don't want to fabricate, the prefab one for $40-ish is a decent deal.
As for the pre-fab, it looks very cool, but since I am not tricking out my engine bay, it is super overkill.
(I'll post some pics later. For some reason I can't post pics from my iPad.)
The bracket seemed to be in very good shaped. I was able to pry off the hose without any damage. So rather than cut the crimped on hose, I left it in place. After taking a 10cm section of hose and putting some silicone inside, I put a section of 8mm dowel in, pushing the silicone ahead to make a solid plug, and clamped it. Dowel wasn't my initial plan, but it will work until I either replace the AOS or decide that the heating effect of the coolant isn't needed in my climate. The same sort of plug was used on the other hose to the AOS. I then blew through one of the hoses to both clear the lines and ensure that I had the right two hoses removed.
Took it out for a drive and the leak is gone. Almost certainly one of the coolant lines has a leak.
NOTE: I found some 9mm stainless steel stock so I cut a couple of small pieces, pulled out those makeshift dowels and plugged it up right. It is SO difficult to find any DIY automotive parts here in Japan. You can change your oil, some filters or buy a battery, but past that everything sees to be about just pimping your ride with fur, air freshners and blue LEDs.
Last edited by Zerpersande; 09-18-2017 at 08:11 AM. Reason: Adding a change I made to the repair and keeping it all in one place.
Thanks. Now I can at least drive it to the golf course on Fridays. The weather here in the Kansai area of Japan is still rather warm to hot. Yesterday it was 27C, so I'm not worried about condensation.
I'm getting ready to tackle the replacement job next. The mechanic I was talking to is out. He did my car inspection and the wheel bolts came back tightened to 160~180 N-M, 35~50% over spec. If the guy can't work a torque wrench, I don't want him working on my engine.
