Oil Test Results
I received my first test results today and all looks very good, but there are a few values that are high and wanted to see what others thing about these specific values. Overall it looks really good.
Boron looks high
Calcium looks high
Otherise, all values are well within normal and better in all cases except the above 2 areas.
Boron looks high
Calcium looks high
If you check here
https://bobistheoilguy.com/engine-oil-analysis/
it says they are additives which can greatly vary in concentration depending on the oil brand you use.
I would conclude nothing to worry about.
IS this oil a 0w-50 racing oil? I dont see a 10w-50 they make.
https://mobiloil.com/en/motor-oils/m...l-1-racing-oil
Base nothing from the first UOA after changing oils. You have cross pollination from the prior oil, and a bit of shock as well.
Until 2-3 services are done, you can’t gather any worthwhile comparative data from UOA.
How does that work if changing from XP9 to DT40 between track events? If I am going from one to the other every change or two, is there no way to get good results?
I laugh when people get one sample and act like it’s meaningful... It’s just a snap shot that’s not meaningful at all.
