996 Forum 1999-2005
Parking on a sloped garage ramp
Old 09-06-2017, 05:39 PM
Andrewck
Andrewck's Avatar
Originally Posted by b3freak
Big question is... Do you cover your rear air vent when washing the car? This is important information to know in order to provide a appropriate response to your situation with an imbalanced M96 motor.
I pour as much water as possible into the decklid to keep my engine cool and prevent any overheating. Typically 3 buckets of ice water does it
Old 09-06-2017, 05:46 PM
nckwrnr
nckwrnr's Avatar
Big question is...
Old 09-06-2017, 06:01 PM
TonyTwoBags
TonyTwoBags's Avatar
While the specific heat of the two liquids is comparable, Porsche-approved coolant is actually the best approach. Make sure to coat the thick copper wires on the passenger side of the engine compartment as they can go bad with age. A good cleaning every now & then improves conductivity in the engine compartment.
Old 09-06-2017, 06:36 PM
extanker
extanker's Avatar
yea right i am the bad guy when i call it TINKERBELLS
Old 09-06-2017, 07:53 PM
Cuda911
Cuda911's Avatar
Sheesh...
You guys are vastly overcomplicating this. He simply needs to let out some air from the up-slope tires to level it.
Old 09-06-2017, 08:34 PM
Woodman71
Woodman71's Avatar
I'm not even sure if this is a genuine question or a joke.
Old 09-06-2017, 09:10 PM
Ahsai
Ahsai's Avatar
Just put 19" wheels on the left and 15" on the right and you're good to go!
Old 09-06-2017, 09:24 PM
kromdom
kromdom's Avatar
my beloved 996 brethren........y'all disappoint me with all these worthless/aimless banter, clouding the MOST IMPORTANT concern of all. WHAT OIL WEIGHT SHOULD BE USED?
after this existential question is put to rest, then and only then will other LESSER concerns be discussed.....like WHERE DO I PUT MY PHONE?
Old 09-06-2017, 10:35 PM
gnarbowski
gnarbowski's Avatar
Speaking of, where the hell should i put my phone in my 1999 996 NB?
Old 09-06-2017, 11:23 PM
Cosmo Kramer
Cosmo Kramer's Avatar
My garage had a slope so I set up parking shims under the tires. I experimented with different thicknesses and used a level on the oil sump plate until I had it 100% level side to side and front / back. I did the same thing for my Boxster as well, and now when I start them up they sound noticeably smoother.
Old 09-07-2017, 12:09 AM
manimal
manimal's Avatar
Glad I don't drive a 996, you guys are a bunch of jokers.
Old 09-07-2017, 03:05 AM
Water Hound
Water Hound's Avatar
Thanks Turbro!
By the way, do you need some free gas for your car? I heard of a guy...
Old 09-07-2017, 12:41 PM
fpb111
fpb111's Avatar
Ok so what the collective is saying is that you might get some smoke at start from oil seeping past the low side piston rings. But you really should not have a problem.
Old 09-09-2017, 11:25 AM
ZuffenZeus
ZuffenZeus's Avatar
Received 1,897 Likes on 1,038 Posts
Doctors tell me that sleeping upside down could be fatal and hard on the body's natural flow of fluids. This might apply to the 996 when parked on a slop. Stupid gravity gets us every time!
Old 07-14-2021, 06:06 PM
ZuffenZeus
ZuffenZeus's Avatar
I recently moved and my new parking spot is on the parking garage ramp. This means that for the next year, the drivers side will be lower than the passenger side when parked. I can alternate which direction I park to 'even things out', but I'm just trying to understand if I'm potentially causing long term issues with oil cooling, etc. by not parking on level surface. Does anybody in this knowledgable crew see this as causing a problem or has my paranoia gotten best of me?
Andre,
Just checking in on the health of your 996. We've been concerned about your parking conundrum.
Quick Reply: Parking on a sloped garage ramp
