2001 911 996 brake pads and rotors what brand
street use only What is the most bang for the dollar brand should i buy pads and rotors I had to pull the trigger and I went with Textar pads and Sebring Rotors I hope I won't be too disappointed thanks all
Using Textar rotors and Akebono pads. Really got tired of the massive black smudge all over the wheels from standard pads and am very happy with braking performance, consistency and no mess.
Does Akebono make pads for the 996 4s? I have looked and I think I found rears but no fronts.. I am looking for a low dust pad and I loved the akebono on my supercharged e46 (once they are broken in)..
NYoutftr , thanks for the info but I am from Minnesota and bought this car in LA California and I leave this coming Sunday and driving it back and it needs a brake job I'm kinda under the gun and I ordered Textar pads and Sebro rotors, thank you
Thanks for the great response. Here's my story I live in Minnesota and bought a 2001 Carrera in Los Angeles. I am flying out Sunday August 27th and driving back Route 66, but before I take it down the road it needs Rotors and Pads. I have rented a garage complete with tools with a hoist for $25 per hour. Question I am a decent wrench but I'm getting a little older, I am thinking 6 hours to do all four wheels any idea what you all think I can get this done in how many hours? Look forward to your estimate and I am really looking forward to the drive back home
You just risk opening up a can of worms if you suffer a part failure while doing the job remotely. What happens if you go to remove a caliper mounting bolt and it snaps, or the threads in the upright pull out? Now you're hosed and you have to wait days for expensive special-order parts. What if the rotor mounting screws are seized in place and you don't have the tools to extract or drill them out?
Just something to consider. If the car is drivable now and safe, I'd drive it home and then screw with it at your leisure.
If everything goes well, your 6 hours will be more than enough. With a lift and good tools a brake job should take half that. I'm just thinking of what happens if something goes wrong.
Received 1,092 Likes
How bad are the pads and rotors? A 2000-mile highway trip is barely going to use the brakes, so if they are not literally worn down to the backing plates I don't see a reason to change them until you get home. Even if they're well below the legal thickness limit, they'll still stop the car fine, and then you can fix them up before getting the car inspected and registered in MN.
This is correct. Be prepared for damnable rotor set screws seized. And get new caliper bolts to go with the project. They are considered one time use although many re-use them. But if one is seized and breaks? That will take some extraction time but if you have new ones to go in, not so bad. Good luck.
In contrast I once drove a car home from a race track with one of the pads worn entirely down to the backing plate after the last bit of friction material evaporated during my last session. It was fine, it just made a nasty grinding noise on stops, but it was time for new pads and rotors anyway, so I didn't really care about what I was doing to the face of the rotor. That was about a 300 mile trip and frankly you really only need to use the brakes a handful of times if you're driving proactively. No problem!
