C4 transmission in a C2
The transmissions will interchange with 1 modification. There is clearance issues with the front output shaft and the radiator hoses as Porsche reroutes the hoses on the C4 to make room for the shaft. You have to grind off the mounting tabs on the front output shaft flange. it is an easy modification.
