Alright screw it I am going for it all!
I am thinking about doing the turbo rear quarter panels, and rear bumper, and contemplating doing the turbo front end of 02 litronics, buckets, fenders, and turbo bumper. Is there anything else that is involved? Has anyone done either conversion? Can I remove the front fenders by unbolting or is there welding required or anything? Please let me know what you guys think! Am I mad? Oh yeah I also plan on running 996tt turbo takeoffs with them and I assume the offsets should be just fine given the new wider oem rear fenders and that the front offset is the same. thanks. Sean
are you kidding me. No way is it cheaper. I already have to replace the right rear quarter panel rear bumper and right tail light, right door etc, so it won't cost that much more for the rear end conversion, The front, now that's a matter of what I can sell the old parts for which are perfect.
GT3 player par excellence
get TT, period.
Well the car was in an accident ,so that is why I am going to replace the rear end stuff with turbo parts, might as well upgrade. I am going to balance it out by doing the front also and selling my stock stuff to fund it. The paint cost will go up a bit but not too much because the right side and rear had to be painted. It will also make it a better job as it won't have to be feathered. So 2k more worth in parts for the upgrade v. 30k for a used c4s hmmm. yeah
SPR,
This isn't a good idea and is really not worth it for just the look. There is a lot more involved than just buying turbo body parts and putting them on. The turbo is a widebody style car. That means you will have to change every single fender on the car, front and back, new harnesses and an assortment of other things. I've been hearing that a 99 to 02 conversion on the front of a 996 is 7K alone. Might be better to just trade in for a newer car.
Bob
Bob
Menace to Society
I don't think you have fully priced the project.
The fact that the car has been in an accident does give you an advantage. But how much? Get 2 estimates. 1 for the car to be fixed as it was, and another for the transformation.
SPR,
If you do go for the conversion, I guess you would be the only person, at least as far as I know to own a watercooled ... C2 widebody. After the conversion, would you identify your car as a C2S? Awesome.
Still waiting for Porsche to come out with a C2S.....
Good for you - go for it. I think you'll like it in the end. Only if you get the parts wholesale and not do the rear quarters but its your money. Ruff is starting to do these narrow body conversions as well. I dont know about having the 99 front with turbo rear- dosent seem right to me- its like putting a 930 wing on a narrow SC.
I've done the conversion on my 99 c2 cab. I would recommend the 02 litronics. depending on how bad your rear quarter is - I would stick with doing the front/rear bumpers only and fix the r quarters and get aero sidskirts. Definitely do the front fenders- no welding required.
Its better not to replace the rear quarters because that is the actual structure of the car and the front fenders are just bolt ons along with the bumpers. I mean fix it if you can and if your car is that badly damaged - change the quarters. It will still look nice to the next person looking to buy a customized car and they will like the fact that you kept it clean not messing with the body frame. After you do this - get some 19's with a fat lip on them and you'll still see a big difference. But thats your call in the end. It looks better to have a customized look rather than looking like the turbo - it will seem more like a kit vs a highly customized c2 by doing the bumpers and front fenders.
These are absolute wholesale prices I've researched below and retail is about double:
Lights- 1600/pair harness 150.00 80/each for the buckets. F Fender 500/pair. If you have clear lights - sell them on Ebay- Boxster owners love them - 400-500 recoupe. Front TT Bumper with all grilles inserts, bottom lip, and light trim for about 800-1000 and they dont include the bottom lip, grills or trim- that'll cost you almost 700.00 alone.
The rear bumper costs about 500- 1100 - that doesnt include the bumper guards- Hard to find (250/pair at cost- i bought these from the dealer) and retainers- about 150.00(trim pieces that go around the exhaust tip grooves and along the bottom The R bumper conversion is better to not split the bumper (thats a saftely issue for me) but to move the mounting point around. (labor will cost you for this) The bumper will fit without cutting.
You will also need the fin covers (black plastic grills that go inside of the vent opeings - ie C4S. They are about 75.00/each from Carnewal.com or (150-200/each from dealerships) Exhasut tips - you can find used ones - these are hard to find but pop up once in awhile 200.00/pair or 500 from dealerships. Lastly you will need to get the pipe that extends from the muffler to the tip s from a muffler specialist becasue they dont exist. I would say the parts would cost wholesale/used for about 5000.00 without R Quarters/Taillights/TT vents/new rear deck(the bolts will be in differenet places for the old deck to attach the r quarters) etc. Also keep in mind if you do R quarters you will need new sideskirts, wheel well covers, possibly suspension mods, springs, etc. The rear quarters and parts will run almost 3-4k and you will need new wheels at least 18X11's or 19x11s - another 2k+.
After paint/labor the front conversion and rear bumper will cost about 7-10k and 10-14k with Quarters,etc. Not including your new wheels. It's not cheap. Find the right bodyshop and have patience- you'll see it hopefully in the spring if you start now.
good luck
good luck
Awesome. finally some encouragement. Well regarding the rear quarters. The one has to be replaced as it got dented a bit and I am against bodyworking it back or whatever, hence the reason for just doing both with the turbo rear quarters. I am going to get a set of turbo rims as they are cheap and I like them. And of course the turbo rear bumper. A couple more questions- do I have to change the rear lights or is that basically because of the fatter turbo decklid?
cool about the front ,so I can simply unbolt the front fenders and do that myself? I have had the bumper and lights out before for doing other projects, so it's not a big deal. I know on the 993t they are epoxied or bead rolled or someting in the inside. On the rear again though, I can get away with not doing the rear quarter panels? I was originally going to do just the bumper, but given that the one quarter panel needs to be replaced and the conflicting things I heard about 99's and the turbo rear I figured it would make the install easier. I still think I would rather do both. I do have to speak with the body shop about the additional labor involved for the other quarter panel etc. thanks it good to know what I can expect ahead of time with fitment etc for when it starts I can address the problems beforehand so I won't get charged R&D fees!
