I smell a little oil burning after oil change
I did a DIY oil change last week. It was an easy, even pleasant experience.
However, it ended up taking 10 quarts instead of the 9 specified to fill it to the full line on the dipstick.
Since then, I smell a little oil burning when I'm driving; especially at a stoplight with the top down. No leaks or drips noted. The exhaust tips are not black.
I'm a little worried about over filling and overwhelming the oil separators... I've heard that these things don't work particularly well.
So, do you fill till full on the dipstick, or fill to 9 qts total?
You are safe if your dip stick shows to line and your electronic shows (when warm) half or higher but not full. If you think you have overfilled it then take out the screw on filter and empty it right there. Easy job.
Received 1,166 Likes
Watch our for liters vs quarts! Not the same thing. My stock engine M96/01 oil change takes 10 quarts plus a little bit more probably because I have the LN oil filter adapter. If you are not beyond the full mark on the dipstick you are okay. Check your oil filler pipe carefully for cracks.
