Boss sound system
Again if you want BT get one of these. Dension Compact BT. This is a newer solution that many guys here who installed older solutions a few years ago might not be aware of. It's much less involved to install compared to the older options and will work with both Bose/MOST and non-MOST factory audio. You can use the radio input or get an aux input installed on your CDR23 by BeckerAutoSound and have aux input. It also has a microphone for phone calls. I mounted mine behind and below the radio and powered it off the unused factory "telephone prep" power cable. Takes all of 20-30 minutes to install.
http://www.dension.com/automotive/pr...ons/compact-bt
^^Link to mfgrs site.
