Weird idle upon startup
Hi there and good day to all!!! Well this all started Saturday morning where upon starting up idle was at constant 2k rpm then after one minute would hunt between 1-2k rpm and when driving it above 2.5 k rpm its running normal til when rpm is below 2k and starts to bog up/down like the throttle had a mind of it's own. What you think it is? No warning lights came up. Thanks in advance : ). Mike
I have been told that a hunting idle problem can be caused by a dirty throttle body. Remove the hose and clean it will carb cleaner while some one holds the gas pedal to the floor. Engine off. Try that and see if it works - otherwise it is something else. Jeff
