Stone chip guards for Turbo S?
Does someone knows the correct P/N for the clear stone guards for the Turbo S model (X79 side vents)? I can't figure out in the PET what is the correct P/N for left and right side.
I ordered from FD but found they are different (for regular 993tt) and won't fit (hopefully will work for the C2 WB) so, I'm clueless which is the correct one.
Any help is very much appreciated.
Received 5,388 Likes
Stone guards are different for the Turbo vs the Turbo S? Did you call Sunset for part numbers? Ask Phil Coy. He's great.
Does someone knows what is the P/N for both sides for regular 933tt (non side vents) stone gaurd film? With this info I could deduct what would be the correct one for the "Turbo S"
Contact FD Motorsports.
Here's the link. They are one of the very best Rennlist vendors, and they have the 993 Turbo S stone guards:
http://fdmotorsports.net/993-stone-guards/
That's interesting! I ordered stone guards for my car in the past from FD. I ordered a set w/o specifying it was for a Turbo S or X79 option as I thought both would be the same, once it arrived I learned that they were different, lesson learned. I emailed them quickly asking if they had a set for the Turbo S and they said they didn't. So I still have that set in the box ready to be used, hopefully it will work on my C2 WB.
I will email them again and see if they actually have a set for my car.
All listed here with part numbers if you still need them!
http://type911shop.co.uk/epages/de86...hop/26/134/142
Looks like
Left 99355998300
Right 99355998400
Also, I spoke with FD, they told me theirs are replica and might not be EXACT size/shape/cut as the original because they used a Turbo S as template.
