993 Turbo Forum 1995-1998
Horn sounding off
Old Sep 21, 2015 | 10:58 PM
Tokyo Joe's Avatar
Tokyo Joe
Default Horn sounding off
Probably a simple DIY fix for this (I hope), regarding the car horn.
The horn suddenly sounds off when driving on an uneven, rough surface, but especially when under braking, becoming more than a nuisance and needs to be fixed.
Anyone familiar with this or had a similar experience?
Thanks,
TJ
Old Sep 22, 2015 | 12:02 AM
AC/911's's Avatar
AC/911's
Bushings wore out, bracket at Porsche parts, they should know with one when you tell Em.
Found this
Old Sep 22, 2015 | 01:41 PM
Tokyo Joe's Avatar
Tokyo Joe
Thanks, you're a legend.
Cheers,
TJ
Old Sep 28, 2015 | 02:06 PM
Norske's Avatar
Norske
Common problem, been posted here several times. Easy fix,. Youtube has demo also.
Old Oct 3, 2015 | 10:20 PM
Tokyo Joe's Avatar
Tokyo Joe
Easy fix indeed. Well, watching my indie do it anyway.
No need to turn off the battery (as per the youtube vid), just unscrew the two screws either side of the steering wheel, unclip the yellow horn connector, then undo 4 further bolts to release the plate. Didn't fiddle with bits of rubber etc, used a new plate for a 993 my indie had in stock. 40 mins start to finish.
Back of airbag...
Horn works when it should do now...
TJ
