993 Turbo Forum 1995-1998
Turbo Specific PSS-9s
Old 10-07-2003, 12:56 PM
SPR
SPR's Avatar
I just got a set of pss9's that I am giong to put in, is there anything else that I would need? I also got the billet hats for the rear so there will be not killing of the mounts etc. I am mainly speaking of the sway bar links for the most part, I have stock bars can I use the stock mounts? thanks.Sean
Old 10-07-2003, 01:03 PM
Jeff 993TT
Jeff 993TT's Avatar
There are some things that are "nice" to have and will make your job easier:
a) Extra lockrings for the OEM sway bar mounts
b) TRG adjustable sway bar mounts ( these have the collars which you can remove so that you can adjust the sway bar mount without R/R the shock )
The stock bars and mounts will work together, check in the 993 archives for the exact distance of the mounts. Otherwise, it'll probably take a couple of hours or R/R to adjust them properly.
Old 10-07-2003, 05:24 PM
SPR
SPR's Avatar
what are the extra lockrings? I am basically just trying to get it "work" with the stock sway bars as I dunno if I want to keep the car or not, if I do though I will replace them with adjustable bars. do I need to get different drop links? I am not following the other mount either do you mean end links? I kinda don't follow what you mean with the other stuff, do you mean I have to shim the mounts from the mount to the chassis to give it less preload? thanks. sorry for not getting it.
Old 10-07-2003, 05:37 PM
SPR
SPR's Avatar
btw your link doesn't work in the sig.
Old 10-07-2003, 05:42 PM
Jeff 993TT
Jeff 993TT's Avatar
I fixed my link. It didn't carry over when this board was converted a few months ago.
Extra lockrings are used to lock the sway bar mount so it doesn't move around. Your stock sway bar should work, as others have done it. Check the 993 archives for more info on this. There's also more info on the drop links that you need to in the archives.
Old 10-07-2003, 06:22 PM
SPR
SPR's Avatar
cool thanks so I can get away with the stock stuff for right now, cool thanks a lot.
Quick Reply: Turbo Specific PSS-9s
