turbo giving heart ache
Love the car. Turbo was leaking oil so replace both turbo charger last month. All was fine until yesterday when i notice the gauge show no boost. 0 bar. Power was there. I think i felt the surge when turbo kick in. Cant be 100 % sure. I only drove it less than 1000 miles a year.
How can i check if turbo working or if any sensor need replacement myself? Dealer is 200 miles away.
will have sleepless night until its fixed.
There are about a dozen or so vacuum lines that can easily come off or crack. Check them all! That is most likely your lack of "boost" on the gauge. Start at both diverter valves that are at the front (forward) part of engine, tucked behind the intercooler. If you have orginal rubber, you NEED to change everything that handles vacuum/boost. 20'year old rubber, regardless of mileage is shot! I was able to pull all diverter valve, ISV hoses and go to an auto parts store. Then I matched the shape of each hose and bought,much stronger, heater core hoses and made them work. Have never had a "blow off" since. Probably need new diverter valves (EVO forged over stock) and check all small vacuum lines.
If your turbos really produced no boost, you would know.
You are taking about an 8:1 compression car here....it would feel like an epic dog.
You may just have a bad boost sensor gauge.
You're not really going to do any damage to the turbos if you're losing boost pressure. The turbos will still continue to run as they normally would, but the efficiency of your engine will deminish. Resolve it as soon as you can. Don't just keep driving it in that state.
I know when I had one of my hoses behind the throttle body come loose I had a CEL but it ran OK but because of the CEL I never got it on boost. But even driving home on the freeway with the windows open I could hear sucking so I knew it was leaking somewhere. After I got the car home and let it cool down it wouldn't even idle with the hose disconnected. So if your only symptom is the boost guage I would start there. Check the electric connections first then look for loose hoses. Otherwise a big leak should be heard but not necessarily easily found.
Find a smart tech shop and do a smoke test to check for leaks in the turbo boost and suction plumbing.
The rubber is typically old and susceptible to cracking and leaks
Ask me how I know.
Ask me how I know.
