Turbo S Rear Wing Question
Has anyone painted an OEM Turbo S rear wing? Does it separate into two pieces with the removal of a few nuts? Any tricks to separating them? Has anyone heard of fiberglass bonding the two pieces together? Thanks in advance.
it was a major PITA to separate the two primary components only because the fasteners has corroded together.
I had to do considerable surgery to get them apart.
Butt I think Scott Mellor did the same and said it was easy-peasy. All depends on if your fasteners are corroded. There are a total of 4 bolts holding the wing to the tail base, two on each side.
Hard to see much less to access. I used a 12" long hex ball driver.
I don't think that there will be any glass bonding the two components.
Then you have to get the grilles off. GACK!!!! super sticky PITA mastick of some type was used. I had to saw it apart using monofilament.
have fun.
yes
have fun.
have fun.
i forgot that i posted detailed instructions while i was still feeling the pain
https://rennlist.com/forums/993-foru...t-993-diy.html
