Check Valve
What is the brand oil filter that you have installed on your engine (small filter)?
Where is you engine oil level (at the dipstick when HOT)?
Did the oil start to leak at the turbo after a oil change?
How much oil is in the black plastic turbocharger inlet pipes?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Lots of forum posts on the whole topic of proper oil MTCE on 993TT and the gremlins that can pop up when making minor deviations / errors.
So upgrades are good ideas 16+ year old cars, but not always the fix to a root cause.
Because Kevin is a busy man.
Read the sticky if you haven't
Porsche branded only oil filters
Fill oil halfway below the half mark on the dipstick. Use 20w-50 oil M1 and get the upgrade lines from Kevin.
Just trying to pass along the good advice I have taken/gotten from the list
Rob
Rob
