A funny thing happened on the way to the track
Well not that funny ..... Tire did not loss air pressure the cord just came apart. Checked the camber and was fine before and after readings. Just a bad tire, I guess Im glad it happened on the freeway at 65 and not at 100+ on the track. The jack broke as I was lowering the car. Fun day !
wow, too bad. glad you're safe!
btw, the spare tire is not intended according to the manual to be used on the rear. If you have a flat on the rear, you are supposed to use the spare in the front and use the front tire in the rear...
yeah glad you are ok. that would have been much more dramatic on track. I have also read in the manual put it only on the front but I would've called a flat bed anyway.
" I have also read in the manual put it only on the front"
