headlamp replacement
my headlamps have many stonechips. design911 sells headlamp glass cover separate from the headlamp unit. anyone has any idea how to replace the headlamp glass. any sepecial tool or bonding material requires?
nope.....easy as pie
literal common sense all that you need. lever releases entire headlight assembly, then the lens just snaps out.
one thing, be careful of dust once inside, i blasted air from compressor before i put the replacement lens on. YOU WILL SEE EVERY SPEC OF DUST WHEN THE LIGHT IS ON B/C IT CLINGS TO THE NEW LENS....so blast it out then quick re-attach to seal.
