Engine Rebuild.. What else to replace?
The engine is out and being rebuild.. Top end planned, split the case for lower if needed when they see the condition.
What items should I have replaced while the engine is out?
Clutch is a given. I have searched and find older posts with different suggestions. Since there is knowledge gained from time and each rebuild/replacement, what is the most current opinions? have read the discussions and would like concise opinions, not debates...
To follow up earlier posts: leak down repeated after more smoke on start up
1. 5
2. 3
3. 5
4. 10
5. 10
6. 52 Exhaust side
1-2-3 side intake and turbo filled with oil.
1. 5
2. 3
3. 5
4. 10
5. 10
6. 52 Exhaust side
You can try the search, both this forum and the 993 forum - there are some very good lists been developed in some of the discussions, just go and find them.
Cheers,
Mike
PS - Not sure why you bolded such large letters - its like CAPS, it feels like you are yelling..
Cheers,
Mike
