Center lock
I searched for answers but cannot find any... Help needed! The center lock button doesn't work at all. If I want to get in the car (both sides) I have to use the key...
(yes I finally bought a 993tt but there are some minor... I hope... things to repair)
The car also starts without the fob pushing button thing... sometimes the red light is flashing (fob light in the clock), sometimes it doesn't...
anybody had this problem before?
nice colour combo!
can't help you but if you search in the 993 NA forum there's many threads on lock problems... seem to recall something about a fuse in the central locking/drive block unit under the passenger seat, problems with the door close sensor/switch in the door etc.
Check connections and fuses first, then remote battery
There's a thread here about remote programming
Then as Basal suggested
993tt are generaly reliable
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
BTW, post pics or be banned...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
thanks! I will post pics as soon as I get her clean! On the first ride home, it was pouring cats and dogs! I also realized that the driveway is to steep and the car too low. For now, she is sleeping in the neighbor's driveway! It's like going to the store the day of the superbowl, buy the biggest lcd screen for tonight game and realize it doesn't fit in the trunk! **** happens! I will just buy a new house (or maybe new coils!)
nice colour combo!
thanks again
Each time you unlock and start the car, how long are you waiting?
Typically I can't remember exact but there is a certain time interval (45 secs) that allows you to disarm/unlock and start the car without pushing the fob.
Steep driveways are a minor pain in the neck... most can be conquered by driving diagonally and carefully. Give yourself room for the greatest possible angle. This tends to annoy oncoming traffic, so be careful. And Congrats!
I tried to look it up, I can see the fuse in the wiring diagram but it does not list the amp. If I had to guess looking at the other fuses, I'd use a 7.5a. Worst case scenario, it blows and you need to use a 15a...
Wonder why someone would remove that fuse? I suppose it could have blown and they didn't get around to replacing it. Did it look like the alarm unit was removed previously? It is working normally now?
The guy on the 993 forum said it was a 15amp. https://rennlist.com/forums/993-foru...t-working.html Should I start with 7.5amp just to be sure?
It looks like the previous owner was pissed with the alarm system/fob because they just took the fuse out… I don't know if it has something to do with the immobilizer… Here it is still terrible outside. I will fire it up in a month when the salt is gone!
For now, it locks after a couple of push on the fob (you can hear a shy locking noise, light flash, horn honk and it finaly locks) It unlock on the first push. Center console lock works fine.
thanks
thanks
