60k service what do they typically do and average cost
My 993tt is nearing the 60k mark and nothing wrong with her... She wanted to know what is the typical cost and what I should look out for and what I rec to change out or replace while the shop has her?
I believe this is when Plugs, Caps, rotors, and compression leakdown test are more critical. Nearing the top end inspection time. Not trying to scare. Just telling you what we went to look for with my girl in the shop. Checking all the seals that are visible.
Also if you want to get into it and be really confident you should check your IMS. No harm no foul but at least you can get a look at her and see when/if the case needs to be split anytime soon.
I would add belts, plug wires on to the list. Plug wires will be expensive but worth it. Those wires are around 15 years old now. Air, cabin and fuel Filter. Make sure the pulley are updated if it is still running with the original.
Did you do a leakdown and compression from your purchase PPI? If so and current oil consumption is normal and car runs fine, then no need to look into compression and leakdown unless something is wrong.
Cheers,
Mike
I would add a brake flush to the list unless you have records of it being serviced within the past two years.
I'd stick with the following guide from Porsche, I also did a PS flush as well.
Price wise I would think it's some decent $ at your indy shop, it's a major service. I'm fortunate to have MikeJ local to me to help with servicing.
If you do some research on the transmission fluid, everyone seems to have diff opinions on what works on their car too. The Delvac 75W-90 has been good for me, but I know not so good for others.
My intermediat shaft seal failed causing oil to leak badly on my car at 60k mi. We had to split the case to replace it. I thought this was the IMS on 993 cars. I know it was 30 hours of labor to fix the leak.
Now I'm wondering. Just checked that invoice from 2010... 33.8 hours. Intermediate shaft and seal replacement.
Heck, I know it stated leaking oil. Smoking and such
Did you replace just the seal or the intermediate shaft itself, or the shaft driving the pump? To split the case is major work!!
Below is a picture of the layshaft on a NA engine - the same design. The lay shaft it the one with the sprocket being measured for backlash. Notice the end of that shaft ends in a recess in the engine case, on a NA engine, this is covered with a lid that is sealed, on a Turbo it part of the drive for the pump. Not that the engine is on its side in that picture.
The whole shaft. It went down in a smoky blaze of glory. Fixed her up. Drove about 1500 more miles. Then tore it apart again. May 2011. Still yet to drive her since. Getting close though. This time is a different story. I think the only thing we kept is the case and the intake manifold. That's soon to change as well. Go billet or carbon, or go home is my new motto
next year I will be getting a lift. Or at least a setup like basal skull has. That's killer get r done tech he has over there.
Thanks so far for the advice... No compression test was done during the phi, the tech said the car ran great and didn't think she needed it.....so far so good. Just wanted to know th cost of the 60k range so I don't feel getting ripped off.... Was told around $1600
But hose and belts sounds like. Goo idea..... I know not part of the 60k
