Texas Mile/ Intercooler build
#31
i'm the f*cking crazy machinist,have been for years! thanks for the complements! my immedate plan is to refine the packaging of the current design. airbox,heater and fans. i will need help in testing this on the track.
#33
some more intercooler ****, I'm not going to bother cleaning up the weld seams at this point until I do more testing. I know it looks restrictive where the end tanks merge but it has a greater cross section than the throttle body. If anyone uses floworks or other CFD software i could benefit from a flow analyzes for the next one.
#35
a pair of core are used on the 997.2 @620 hp, I'm using three cores, so I would safely guess over 620. I have a bit of work to do to prove how well it works. I need a track mule
#36
^^ Timing is everything ... or nothing. I get almost unlimited time at Monticello, and at 3+ miles it would be a good venue. Unfortunately it just closed for the season. Reopens in late April/early May.
#38
currently I'm using a cone filter attached to the Maf. I will fab an air box with a 14"x6" panel filter, this setup can be used without too much hassle. One has to change center section, reconfigure some plumbing, I'm using a in line blower to replace the heater/ blower, works great and half the size,I still need to fab an air box, I mocked one up from cardboard.
ba
ba
#39
Basel skull, it was your DIY intercooler thread and data logging that inspired me to build an intercooler. thanks for posting your results. this set up would require about 8 hrs of engine prep before you could bolt up the intercooler.
#40
cool. was wondering about the plastic blower, would love to see pics of that too. I might look at the centre section to see if it's something I can fab as well. I don't have your skills or the equipment but as you know I like tinkering and learned very young that I can do most things if I put my mind to it... I've been running out of projects and will consider the 3 front to back cores that you, and Sonny1 (and Spartan I believe is working on one) fit. Although my engine doesn't need it! great work!
#42
Do you mean that you'd produce a custom centre section for the intake manifold to replace the 993 n/a one? Sounds like a plan.
I think you'd have a surprising amount of interest in a group buy if you put together a package of intercooler, airbox and centre section (na or custom).
Steve
Steve
#43
993TT
200 mph on stock tranny? I raised the question before on the Ruf Turbo R, I've seen pics & looks like 7k rpm's right at 200 mph,tire diameter can help as well. In first pic it looks like OBC says 200.
#44
The last pic is pretty impressive with speedo 200+mph with only 0.8 bar boost.
Here was what Car magazine maxed a stock 408PS car at back in '97
